Maintaining Scale Between Acad 19 and C4D
When I export a mesh into C4D from A19 everything is fine....but when it is sent back everything is at 10% of original size.....my original drawing units are set to cm in A19 as default is cm in C4D...I am unable to resize embedded object until I turn object into a morph....help.....I am using sculpting tool in C4D to create a sculpted wall
0 Replies 0
