Making a perfect presentation
Hi guys,
I'm new at the using the archicad. I can able to draw what i want but i'm having a problem about how they look. How can i make my drawings on archicad, look like as they drawn in autocad? This is very important for me. How can I make them look more professional? (Line thickness, wall hatch etc.) Is there a add-on for that purpose?
Thank you in advance.
Erwin Edel
The things you mention are in ArchiCAD.
Line thickness is controlled by pens, which you setup and assign to lines. For example lines used in composites.
Hatches are available as fills either solids / emtpy / percentage, vectorial or symbolic (also stretchable/scalable).
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
