Visualization
Render your model with built-in or 3rd-party solutions
Mapping with a Jpeg and object appear
I have been tryin to finish up my interior scene and evertime i add a texture to an object, it places older object i have worked with previously in my scene. Sometimes i my objects the are currently in my scene would just disappear and leave a dot where it used to be. I am having to restart archicad over and over when this happens. When adding a jpeg to something as a texture would also cause this problem. Is there a fix out there for this and if so where can it get it from.
T.I.A
1 REPLY 1
Djordje
This all sounds like you are having problems with your library management. The dots mean that the object is not in currently loaded libraries - which any freshly saved object is not.
Reload the library, not restart ArchiCAD.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
