The real problem of the integration in ArchiCAD is the low texture quality of the default ArchiCAD materials. You can make a nice model, but you have to either replace all textures with better ones (high-res, less visible tiling, less saturation) or define/load a Maxwell material for each used material. This can be cumbersome.
But if you want the best result, you should probably go the extra mile and make some thumbnail sheet for maxwell materials and apply them. Especially tricky materials such as glass, chrome, aluminium and velvet will never look great when you only use a default ArchiCAD material + texture.
In fact, that is often the problem with ArchiCAD renderings: try to apply decent textures or replace all materials with optimized materials for your rendering application of choice.
I've tried the ArchiCAD 10 plugin to render with Maxwell and the process is smooth. I was struggling with the Maxwell textures in the beginning (the additional downloads), but once they were into place, the renderings using Maxwell materials were significantly better then the ones using ArchiCAD textures. Now I have to get rid of the demo-watermark
š
(Actually, they offer an educational version, where you pay about $100 for three consecutive years and then you have a full license. Still, Autodesk VIZ 2007 student version is free and so is Artlantis Studio educational, so hard to sell to students...)
Archicad-user since 1998
my Archicad Book
