2006-10-03 06:45 PM - last edited on 2023-05-11 12:30 PM by Noemi Balogh
2007-12-10 11:04 PM
2007-12-10 11:06 PM
Colyer-Lloyd wrote:I assume it can be done in both, I have not used 1.6 yet. I just posting examples of what it can do, I don't think there renders were done in archicad.
Was this done in Studio or with the plug-in?
Pretty cool.
Justin
2007-12-10 11:08 PM
Danj wrote:Dan, your images are very cool, but please use the forum's attachment mechanism instead of posting in-message links. Your method slows down loading a great deal if you're on a slow connection!
Maxwell 1.6 out now, displacement is very cool.
2007-12-10 11:19 PM
Thomas wrote:sorry, fixedDanj wrote:Dan, your images are very cool, but please use the forum's attachment mechanism instead of posting in-message links. Your method slows down loading a great deal if you're on a slow connection!
2007-12-17 08:31 PM
2007-12-18 09:25 AM
Colyer-Lloyd wrote:Nice rendering, but 15 hours on a quad? For a single image? I am not sure if this is still practical when deadlines are getting closer.
A recent rendering.
15 hours on quad core
S.L. 18
Justin
2007-12-18 02:27 PM
2007-12-18 03:29 PM
another Moderator
2007-12-18 03:53 PM
ejrolon wrote:Does the VRay-animation produce flickering? This is not noticeable in a still image. I ask this, since I wouldn't imagine rendering an animation unless I can be sure that no (or only minor) flickering occurs.
Vray example, Core2Duo.
1 minute rendering time, it is a frame from an animation test of Vray running under C4D in OS X.
The problem with the 15 hours is that if you need to produce more than one Image it adds up to an impossible number . My personal target for rendering time for single images is no more than 20 minutes for tests and final images between 1-4 hours, but usually the test image is good enough.
2007-12-18 04:00 PM
another Moderator
