Visualization
Moving model after Archicad import to Twinmotion
defariaferreira
Help please
I can move the ground, but I can't move or delete the archicad import.
What am I doing wrong?
Thanks
defariaferreira
thank you Carstenem
Resolved
After importing the Archicad file into Twinmotion, I create a new container, insert the archicad file into the new container and change the name of the container and that's it, I can move and rotate the imported file without losing the connection to the archicad.
Sorry for the bad English.
Thanks
Carstenem
You have to break the instance first. Sometimes this is not working, then rename the instance/layer first then break instance. See markup.
Cheers Carsten
Carsten
www.asmtechbase.com
https://www.youtube.com/asmtechbase
AC 3 to 26 -Windows 7 - 24GB - 8core 4.4Ghz
defariaferreira
thank you Carstenem
Resolved
Thanks
Carstenem
Nice, great you resolved this, your english is pretty good too
Cheers Carsten
Carsten
www.asmtechbase.com
