defariaferreira
Moving model after Archicad import to Twinmotion
Help please
I can move the ground, but I can't move or delete the archicad import.
What am I doing wrong?
Thanks
1 Solution
defariaferreira
thank you Carstenem
Resolved
After importing the Archicad file into Twinmotion, I create a new container, insert the archicad file into the new container and change the name of the container and that's it, I can move and rotate the imported file without losing the connection to the archicad.
Sorry for the bad English.
Thanks
Go to post
3 Replies 3
Carstenem
You have to break the instance first. Sometimes this is not working, then rename the instance/layer first then break instance. See markup.
Cheers Carsten
Carsten
www.asmtechbase.com
https://www.youtube.com/asmtechbase
AC 3 to 26 -Windows 7 - 24GB - 8core 4.4Ghz
defariaferreira
thank you Carstenem
Resolved
Thanks
Carstenem
Nice, great you resolved this, your english is pretty good too
Cheers Carsten
Carsten
www.asmtechbase.com
