I must say that bleachmaking plants have never looked so fine. I remember that our neighborhood bleach making plant had this icky vat. And the corroded stirstick! Right from a horror movie!
1: replace tiedyesky with Lightworks graduated.
2: Four suns??? What kind of universe is this?
replaced three suns - used as skylites with windolites
3: Camera light 90%??? I will shoot the next guy who uses camera light.
Unless he is trying to simulate a flash picture. Then it is all right as long as it is in a bar and he is using the "Drunken office colleague group" bitmap archicad figures. Here you make the light white - BTW how do you change the camera light color? Don't waste too much time on it.
4:BuiltinSun off - this generally works counter to the sun object - pick one or the other
5: switch to "best" method ensures full raytracing calculation - see reflections in windoz.
6: used custom glow material for acrylic skylite diffuser- behind acrylic diffuser lens - debatable benefit.
7: put windolites at each skylite opening.
8: floor??? : water?? bleach? swine fluids? rubber? liquid rubber! My secret material - recipe found in book.
9: swung the sun down and around for sunset-like penetration
10: sun is always "warm." sky is always "cool." Like your nipple ring:
"Cool, dude!"
11: wall blocks - increased ambient reflectance to 75 - many lightworks materials do not reflect enough ambient light.
12: made interior ambient warm
13: extended ceiling over room adjacent to prevent overexposure....
14: hate kawneer aluminum - find a brighter surface - selected white plastic like room adjacent - see - happier already!
15: should happyup guardrails, too - who cares what material definition is - make space and elements within lively, not deadly.
16: raised fluid level of boiling swine entrails for drama.
17: turned up left windo uplite to 80
18: pulled levels in photoshop since scene murky lacking real interior lite - want to consider that problem in design.
19: played Duane's viola.
Dwight Atkinson
