While the turkey cooks.
Pro:
1: entry brightener excellent to help modulate otherwise plain facade.
2: excellent textures grass and asphalt.
3: Shows off what looks like the cinema picture trees on invisible plywood panels well.
4: foreground shadow excellent because it infers a world outside the view and gives "ground" to the shot.
Con:
1: see my red tone cropping suggestion top, right and bottom
2: Prominent red bush in lower left is distracting
3: White curb major distraction - move camera closer to entrance since it is the subject of the illustration - plain repetitive facade does not help your rendering - just enough to tell the story. Consider a square composition. (red line)
4: will the wall bricks really be that variegated? At this distance they will undoubtedly look more uniform in color.
5: second story windows terminate too close to roof line - ask any ancient Greek person.
6: likewise the entry - arched window, columns all appear confined. Should feel more spacious and gracious - add some height to entry wall.
likewise downlights - bad place for them anyways, but they should be out in the daytime.
7: Tree leaves intrusive. shift to the right four feet or so.
8: oversaturated
my crop suggestion desaturated on the right.
too lazy to move the green leaves.
Dwight Atkinson
