Pavers look milky in 3d
I think I found these paver paterns in the archicad folder.
Is there a way to get them to read better than this, they look milky like they are being seen through a fog or somthing?
4 Replies 4
David Maudlin
Jonathan:
If that texture is pavement-04_d100.png, than that is how it looks, it has a dull appearance. To change the color intensity you could edit the texture in an application like PhotoShop.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks David,
Thought I might be missing some setting somewher. Short of going back up and getting a picture of what's therer and creating a new one I can live with for now.
David wrote:
Jonathan:
David
Here's that texture file made more contrasty in Photoshop, in case it helps. Can't say I've ever seen such colorful pavers. 😉
Thanks Karl,
We have them here in Palm Desert. I'm going to see if I can replace the
archicad file with yours and see if it works (aligns well)
I don't have the photo shop thing. too expensive and a bit intimidating for my pea brain:-) I'm just able to get AC to do what I need after using since version 5 or 6 🙂
