Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Visualization
Photostitching
Steve Jepson
Could anyone recommend some good photo-stitching software ?
I am using an A700 with a SAL1680Z, SAL135mm F1.8Z
I want to stich 3 or 4 pictures to together end to end for use as backgrounds in rendering.
Do I have to use a panoramic tripod for this or does it not matter that much what the overlap is?
Something like this www.panoramafactory.com/index.html
is what I think I am looking for ?
Any suggestions ? Any one photo-stitching to make backgrounds for renderings ?
10 REPLIES 10
Chadwick
I ran into a program called Autostitch that is free of use and relatively easy to learn. I used to stitch together shots of the Swiss Alps I took when I was over there and it worked absolutely wonderful.
Autostitch
RA 2012 x64, Piranesi 6 Pro, Sketchup 8, Windows 7 Pro x64, Intel Core i7, 10GB RAM, ATI Radeon Mobile 5870
Steve Jepson
wow. I like this one.
http://www.cs.ubc.ca/~mbrown/panogallery/redtit.html
free is good.
I've used PTGui and was hugely impressed with the result - even from handheld shots to make up a 360 panorama. Quick to produce, and it's very smart.
Once you have the result, I recommend cutting out the skyline in PS and making the sky area transparent; cropping as low as possible; saving out to TIFF; mapping it to the inside of a circular wall, keeping the height as low as poss as it affects the sun when it's set to a low angle. Do some maths to determine wall size relative to image size, so it's seamless.
I use this setup + a generic sky background that matches the light quality of when the pics were taken.
Dwight
What complications occur when the wall is a complete circle?
Dwight Atkinson
Steve Jepson
64bit demo here http://www.ptgui.com/download.html
vistasp
If you want free, open source AND cross-platform, go to:
http://hugin.sourceforge.net/
And don't forget to get the plugins for automatic control point creation and blending.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
Good point Dwight ... It wasn't a complete circle - I made it as close as possible with the smallest of gaps (which doesn't get noticed). Closing the circle makes the wall disappear/go haywire/????
So why can't I close the circle without these "complications"?
Dwight
The outcome i was expecting was that a completely circular wall splits into two equal parts. Using one map as a wall material requires special 3D material alignment.
Dwight Atkinson
henrypootel
AutoPano from Kolor is a great product:
http://www.autopano.net/
It does pretty much everything for you, gets rid of ghosting automatically, and supports HDR. It's a good 'un.
Josh Osborne - Central Innovation
HP Zbook Studio G4 - Windows 10 Pro, Intel i7 7820HQ, 32Gb RAM, Quadro M1200
