ā2009-06-16
04:53 AM
ā2023-05-11
03:09 PM
Noemi Balogh
ā2009-06-16 05:41 AM
ā2009-06-26 11:05 AM
ā2009-06-26 11:43 AM
ā2009-07-01 04:03 AM
I am using 3D documentation recently, it works fine for me in presentation plans.For presentation purposes, where you are trying to indicate sunlight direction and provide some dynamic quality to the drawing it is fine, however when the objective is to determine the ratio of direct light/shadow on a specific surface (e.g. floor slab or adjacent building face) then the 3d documentation has the same shortfall as the cutting planes, that is, the elements that are not visible in 3d (so as to be able to see the required surface) do not cast shadows.
ā2009-07-01 08:48 PM
ā2013-11-13 04:38 AM
(3. use control-C to copy - in the dialog box that comes up, select none for construction elements, polygons only for shadows, and OVERLAPPING for polygons.)What if this dialogue box does not appear?? The whole thing copies and slows down archiCAD considerably.
ā2013-11-13 06:10 AM
ā2013-11-13 07:23 AM
