Visualization
Plans and Elevations with materiais in dwg and jpg
2 questions:
1 - how to save a plan of each floor and sections and elevations with the materials and save as dwg?
2 - how to render the plan within each floor and cuts of the building? I think that through the "3D window" axonometric view "does not works ...
1 REPLY 1
Hi and welcome to the forum Sofia!
First question... You can't see the material textures in your plan view... but you can use "Bitmap fills/Tramas de Imagem" to apply real textures to your plan view... and save them as a regular dwg.
Second one... Try a search "3d Cutaway/Secções 3d"in the ArchiCAD Reference Manual... I think that will do the job.
Personally I'd render a"3d Cutaway/Secções 3d" top view of the building... Quick and easy!
