Plans and Elevations with materiais in dwg and jpg
2 questions:
1 - how to save a plan of each floor and sections and elevations with the materials and save as dwg?
2 - how to render the plan within each floor and cuts of the building? I think that through the "3D window" axonometric view "does not works ...
Hi and welcome to the forum Sofia!
First question... You can't see the material textures in your plan view... but you can use "Bitmap fills/Tramas de Imagem" to apply real textures to your plan view... and save them as a regular dwg.
Second one... Try a search "3d Cutaway/Secções 3d"in the ArchiCAD Reference Manual... I think that will do the job.
Personally I'd render a"3d Cutaway/Secções 3d" top view of the building... Quick and easy!
