Printing Images
Please could someone suggest why screen images of renders done in Light Works (which look good enough) do not print very well at all. So much so that we are unable to print and show our rendered models.
3 Replies 3
David Maudlin
William:
It could be the image resolution. Normally, a printed image the same size as a screen image will need a higher resolution (more pixels) to print decently. What is the size (inches) and resolution (number of pixels) of your image? It would also be helpful to post your printer specs, as someone may have experience with the particular printer.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David:
Relevant Specs are
Pixels: 300dpi
Image Size: 10 x 6 inches
Printer Specs:
iR 3170C EUR Canon PS
and HP Designjet 1055CM.
David Maudlin
William:
So to be clear, the number of pixels is 3,000 x 1,800 as seen here? If so, the number of pixels should be fine. If this is the case, then a fuller description of the difference between the screen image and the printed image would help.
