‎2003-12-15
05:42 PM
‎2023-05-11
12:42 PM
Noemi Balogh
‎2003-12-15 10:41 PM
‎2003-12-15 11:18 PM
‎2003-12-15 11:22 PM
‎2003-12-16 11:48 AM
‎2003-12-22 02:26 PM
stefan wrote:You can import an AutoCAD dwg file into a library object type one command in the 3d Script ROTx 90 Insert the object in your model you will then have the 2d AutoCAD dwg showing in the 3d window in shaded and wireframe mode. Remeber it won't show in a Photorendering though.
I don't think you can "elevate" an AutoCAD imported 2D-line into a 3D-model.
You can draw over the AutoCAD drawing in ArchiCAD and make real ArchiCAD objects.
