Realistic objects in web.
Hello all...
I am working on professional rendering activities and i am using archicad to modelate.
Usually i buy my objectes in www.turbosquid.com and they have very good objects in 3dsmax format (and other) that i use in archicad (converting them in zoom gdl).
well, i need to know another web site with Excellent objects...they have to be perfect, and real (price is not the problem). I need really bathrooms....toilet, bathub,,etc, etc. Kitchen furniture, etc...
If someone can help me, please say something.
Thank you all
best regards
10 Replies 10
Petros Ioannou
Try http://www.archiforum.de
It has some real world GDL objects for free
You just need to register.
HTH
Petros
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
thanks.....but i really need realistic objects...
normally they are in 3ds max format, because that in gdl are not perfect for phorealistic view.
there's an example of what kind of object i need.....with detail.
thank you all..
best regards
stefan
http://www.fritzhansen.com/
http://www.e-interiors.net/
http://www.ultra3d.com/
And then also these portals:
http://www.3dcafe.com/
http://avalon.viewpoint.com/
http://www.renderosity.com/
http://www.autodrop.net/
Archicad-user since 1998
my Archicad Book
Thanks Stephan,
You are one awesome Link Master! The 3ds funiture available at no cost, will guarantee a good looking interior. I just wish I had clients with such exquisite taste, Italian Furniture isn't exactly common.
Mark
stefan
Imagine the possibility of having a more powerfull version of GDL, that can be also be used from inside Cinema4D, 3ds max, Maya, ...
You export an ArchiCAD model (with GDL-objects that are generating ArchiCAD-efficient geometry) that can be loaded in your 3d-animation tool that can generate a better looking render-ready version!
Parametric Objects but with the full power of the 3D-polygon crunchers!
my Archicad Book
Gorazd
I have been browsing these links and tried to use i-drop technique in ArchiCAD 9. It works OK but only in 2D. Does anybody has any experience with this?
Gorazd Rajh
From AC 6.5 onward, i9-14900HX, 32 GB RAM, RTX 4060, Win 11
rgarand
Also try:
http://www.dosch3d.com/products/3d/
Robert J. Garand
ArchiCAD USA 28-Build 6003 USA FULL and ArchiCAD USA 29-Build 3000 USA FULL
Windows 11 Prof (64 bit) - Intel i9-14900K CPU 3.20 GHz - 64 GB RAM - NVIDIA RTX 5000 Ada Generation
stefan
I have been able to add 3D Furniture into my ArchiCAD scene.
Check out the iDrop models from Vitra:
http://www.vitra.com/resources/cad_library/structure/nl/nl/idrop/main.htm
my Archicad Book
Gorazd
Thank you Stefan. Just a simple CTRL key and it works. It is pitty though, that you dont get parameters for objects as well, or is it again just another key to press?
Gorazd Rajh
