We value your input!
Visualization
Redshift Rendering Limitations AC25 & AC26
mthd
Ace
Hi, can any experienced users with the Redshift Rendering engine please give me some feedback on how it is performing for you and are your happy with the results ?
This article below highlights the limitations in AC25 & AC26 are all these limitations still applicable ?
https://help.graphisoft.com/AC/26/INT/_AC26_Help/140-3_Redshift/140-3_Redshift-2.htm#XREF_34278_Curr...
Thank you in advance.
AC8.1 - AC28 ARM AUS + CI Tools
24C GPU 7.8TF 32GB RAM OS Sequoia
Keep it Perpetual !
10 REPLIES 10
Redshift should work on that machine. Here is an earlier performance test of video chips in Archicad with Redshift rendering and there are results for M1 CPUs:
https://community.graphisoft.com/t5/Installation-update/Performance-review-with-M1-Pro-and-M1-Max/ta...
So, it should work. I don't know the reason why it does not. You should report this to your local Graphisoft reseller and ask them for help.
