Visualization
Render Farm suggestions for ArchiCAD
muzedesigns
Hi community,
Does anyone know of any render farms that work with ArchiCAD. I have a bunch or renders to process and need some extra processing power.
Any help would be greatly appreciated
Chrissy Avramidis
|| ArchiCAD Versions 7-22 ||
|| 27inch iMac Pro (2017) | macOS High Sierra 10.13.6 | Processor 3 GHz Xeon W | Memory 64GB 2666 MHz DDR4 | Graphics Radeon Pro Vega 64 16368 MB||
Erwin Edel
You can export your render to a cinema 4d file, maybe that opens up the options a bit more.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
muzedesigns
Thanks Erwin,
Is this a process you use often? I'd assume it would be a easy switch as the cine-render shaders would export back into their native 4D?
Really interesting - let the search for more info begin!
Chrissy
Chrissy Avramidis
Erwin Edel
I've never used it, but I know that under the render button there is the option to save c4d file, which I assume is some sort of 3D scene ready to render with cinema 4d.
www.leloup.nl
