DaniBaiana
Render is blurry
Hi everyone,
can someone please help me understand why my render is being strange. In a photo in attach you can see that chairs are looking strange. I made few other photos and it's even worst. In my last project everything was working fine and I didn't change anything.
Thank you so much
3 Replies 3
I don't see anything amiss in your render ... other than if you did not intend to use the unusual surface material showing torn/damaged fabric?
DaniBaiana
No I don't that is what I was reffering.
You'll need to look at the parameters for the chair to see if the surface material is shown there so that you can change it to a normal fabric.  If it is a downloaded object with the material embedded, then your only easy option is to convert one of the chairs to a Morph and then change the surface.
