2024-02-24 03:55 AM - last edited on 2024-02-24 04:03 AM by Karl Ottenstein
Hi everyone,
can someone please help me understand why my render is being strange. In a photo in attach you can see that chairs are looking strange. I made few other photos and it's even worst. In my last project everything was working fine and I didn't change anything.
Thank you so much
2024-02-24 04:04 AM
I don't see anything amiss in your render ... other than if you did not intend to use the unusual surface material showing torn/damaged fabric?
2024-02-24 11:34 AM
No I don't that is what I was reffering.
2024-02-24 05:12 PM
You'll need to look at the parameters for the chair to see if the surface material is shown there so that you can change it to a normal fabric. If it is a downloaded object with the material embedded, then your only easy option is to convert one of the chairs to a Morph and then change the surface.
