Learn more
Render problem!!
objects don't seem do get rendered properly, although i have used the same objects on another project and everything rendered just fine. What is happening here??
6 Replies 6
Post moved.
Please don't just post everything in the 'Archicad+' section.
Please look at the section descriptions for a relevant section to post in.
same problem in another area
Barry wrote:
Post moved.
sorry about that, thanks for moving the post
Lingwisyer
Guru
Do they render fine in a fresh file? In a 3rd project?
Ling.
Ling.
Yes these objects render fine in a 3rd project! i justed tested it
Also the representation of some textures is broken, but when i import these models in a clean file everything is ok
