Rendered Fly through
Ok all bit of atricky one.
Im dooing a flythrough and the client wants an animated white card model of the building starting at ground level and then looking down at the roof.
Seems simple. Flythrough with photorender settings on.
Unfortunately every time i switch the settings to render in cinerender the video publishes blank. It works if the settings are for 3D window and previously on a different path.
Also the idividual camera produce rendered stills.
To say im confused is an understatement.
1 Reply 1
Brian Spears
*bump*
I'm experiencing the same thing - 3D Window Publishes just fine, but setting the saved Views generated by Cameras to use the PhotoRendering Window results in a broken published file, regardless of how many frames I have between Cameras (including the minimum 1).
Brian Spears
BIM Manager, Steele Group Architects
Winston-Salem, NC
AC27 USA on macOS
