Modeling for visualization is not the same as modeling for generation of construction documents.
It is important before you start the job that you’ll agree with your client about the specifics of the visualization:
• How many images
• Images of what
• Size of images
• The nature of additional props
Once those things are determined it becomes easier to budget the project.
It is also important to note that once the required images are decided upon, the modeling effort can be directed only towards that which appears in the frame.
Take into consideration that ArchiCAD will be useful for fast modeling of a simple structure like the one you’ve presented. However you will find that by using LightWorks as your main rendering engine, much of your time (probably around 50% of the entire production schedule) will be spent on visualization.
Here are some average sample prices advertised by various visualization studios. These sample prices are based on modeling out of 2D data
Typical Apartment (2-3 bedrooms)
Up to 5 unique living areas such as living area, kitchen, dining area, lounge, and balcony, Up to 2 still images per area within the apartment $4,500
Typical High-rise Condo Building (up to 20 floors)
Including; pool area, lobby and one complete apartment up to 2 bedrooms.
Up to 2 still images per area including exteriors $19,000
Additional apartment up to 4 bedrooms: $5,500
Additional Penthouse up to 6 bedrooms $7,500
Typical single family dwelling (1500-2500 Square feet)
Up to 5 unique living areas such as living room, kitchen, dining area, family room, and entry, as well as full exterior and yard
Up to 2 still images per area within the apartment $7,500
I hope this helps
