Visualization
Rendering a material
I can't find a same topic so will open this one
I create a material, apply it to a wall and when I render it - It has default colour of material which I've duplicated while was creating my own material...
Here are pics (the first one is a simple 3d view and second is a rendered scene)
4 REPLIES 4
Thomas Holm
When you create or edit a material, it's practical to start with it's Internal Engine appearance (it will always be used in shaded sections for example), and you set Vectorial Hatching there.
Select engine below "Create Preview".
Next, check Open GL appearance.
Then Lightworks Rendering Engine. If you open the Lightworks shader settings, there's a Match with Interna Engine button. Click that.
Customize later.
Thank you Thomas
Thomas Holm
You're welcome. But please replace your in-text picture links with posted attachements the normal way. Your pic links slow down the page loading enormously!
I didn't know that only one attachment is allowed per post...
Anyway, I have the answer so It doesn't matter
