Visualization
Render your model with built-in or 3rd-party solutions
Rendering external textures and colours
Hi, I'm new to archicad and I have just learnt how to add external textures to my project. I'm just wondering how to render the external textures using Lightworks Engine because i just can't seem to. What i did was i duplicated an existing texture...renamed it and changed the texture with an external texture. This only works when I use Internal engine to render, not lightworks. Is there a way to actually do this? I'm sorry if this is a silly question. Please help.
2 REPLIES 2
Try "Match with Internal Engine"
stefan
This is indeed the correct solution, but it clearly shows that the two engines are entirely different beasts, not speaking (much) to eachother. Setting the textures should be identical to both and only when you want, you could replace the texture with a dedicated LightWorks procedural shader. This should be optional.
Archicad-user since 1998
my Archicad Book
