moritz61
Distorted Texture Lines when rendering
When rendering a surface with a brick wall texture, Archicad seems to distort and bend the brick contours, even though it's a flat surface. My curret rendering engine is Cineware, is there any setting to fix this?
runxel
Looks fine to me! That's not an issue of the renderer or Archicad (or you for that matter).
This is just Moiré, and will just happen.
Luckily there are some ways to mitigate it a bit. Look in this forum, there are many posts about this especially with bricks. Somewhere I explained how you can lessen the effect.
