Visualization
SKETCH STYLES
anyone know where I could see images of the different sketch style effects?
7 REPLIES 7
try this link: http://www.informatix.co.uk/piranesi/index.shtml you“ll see a good variety of styles.
http://www.sketchup.com/ also is agood source.
good luck
I am actually refering to the sketch styles within ArchiCAD 9's rendering engine.
I wanted to have a simple sheet showing the same model rendered with the different preset styles so that I don't have to go through them one by one rendering my model.. I remeber at a previous version it was within the help files. it's no longer there..
At one point I was thinking the same thing. I ended up creating a simple model and literally rendering x amount of times with the different default sketch settings. After saving each one, I now have a record of the visual styles.
Still though, I'm not aware of an existing reference guide as such. (Then again I'm no expert!).
gpowless
Ok.....how's about sending them to a .pdf & sharing them here with us?
Intel i7-6700@3.4GHz 16g
GeForce GTX 745 4g HP Pavilion 25xw
Windows 10 Archicad 26 USA Full
fuzzytnth3
I came across this post having just rendered every default style last week to see which was best so I've complied them into a PDF for you all.
It exceeds the max attached file size (the pdf is 460k) so I've posted it here
homepage.mac.com/fuzzytnth3/fuzzyblogs/tips/C1514112824/index.html
Enjoy
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
Rakela Raul
thanku, good deal..
and i liked ur web site
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
thanks, that's exactly what I was looking for..
