Visualization
Save as 3ds
eldhead
When Im trying to save to 3ds from 3D-window, I get this error:
improper fileformat
If I dont use any textures it works fine.
Archicad 7 - 24, HP ZBook 15 Mobile Workstation, Win 10
14 REPLIES 14
Which version AC?
Dwight
can the problem be that you have a texture image format 3Ds can't use?
Dwight Atkinson
eldhead
ArchiCAD version 8.1
!! Tried with .bmp, default ArchiCAD image file format from export to 3ds without success. However, .jpg seem to work!! Thanks for the new input Dwight.
Dwight
Ben Frost jump in now.
Dwight Atkinson
Actually, it's Stefan's turn to double/triple post!
Do you have the updated 3DS exporter from the German web site? Do a search on this forum to find the address... Stefan has mentioned it several times.
[Edit: Oops. Stefan has mentioned the importer. Sorry.]
AC 29 USA and earlier   â€¢   hardware key   â€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
eldhead
3DS exporter?
Dwight
See:
http://plugins.angstraum.at/
for ArchiCAD import wizard to import/export ArchiCAD files to 3Ds Max.
Dwight Atkinson
eldhead wrote:
3DS exporter?
Oops. Sorry. I was really tired when I posted, and realized what I had said as soon as my head hit the pillow.
My comment has nothing to do with the question, and yes, Stefan posted a link to (and a copy of) an add-on for importing 3DS files into AC, not an updated exporter:
http://archicad-talk.graphisoft.com/viewtopic.php?p=16758#16758
eldhead
See:
Aaa..it gives me a second error message; "no materials in the scene", but they are there, I can see them in both ArchiCAD and saved as bmp:s in the 3ds folder.
