Visualization
Render your model with built-in or 3rd-party solutions
Saving favorite settings in 3D document
Hi everyone,
I've been using 3D documents in my presentations. I cannot find a way to save my favorite settings, as I can do instead for plans, elevations and so on.
Is it possible to do it in AC13?
Thanks!
Enrico
5 REPLIES 5
Enrico wrote:
Hi everyone,
Sure you can http://archicad-talk.graphisoft.com/viewtopic.php?p=165074
I don't know if this is what the OP meant but I want a way to save favorites in my 3D Document settings so that they are automatically set for every new 3D Document I create...
Steve,
Just right click on the "3D Documents" folder and and change the settings to what you want.
You can also clone the "3D Documents" folder so that you can set up views that automatically set the correct layers, scale, etc. for using in your layouts.
Link
Barry wrote:
Steve,
That's the way to do it!
In a template you can also pre-make a bunch of empty 3D Document Views, complete with all pre-determined settings, including Filtered Elements & Projection Settings, including Sun Settings (for ready-to-go sun studies).
Link.
It is a wonder that I've been using Archicad everyday for this many years and never knew about this before....
thank you
