Scale problem when importing into max
I cant get the scale right when importing into max. When it comes into max its way out of scale (too Small). I don't know the scale factor in the Archicad 3DS export options to scale by. If the archicad file is correct inside archicad, shouldn't it come in the same size in max??? Any help would be appreciated.
4 Replies 4
Ben Odonnell
When you save out to max, you should use a scale factor of 1000. Then it should work ok in Max.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
giza
check out this link:
http://plugins.angstraum.at/archicad_wiz/index.htm
http://plugins.angstraum.at/archicad_wiz/faq.htm
i hope it helps
Gezim Radoniqi | Architect | BIM Manager @ 4MGroup
ArchiCAD user since version 6
AMD Ryzen 3950X CPU, 64 GB RAM, NVidia RTX 3060 12GB
Djordje
Depends on the unit settings.
When you export to 3DS, the export engine is asking you what are the ArchiCAD units used.
Then, when opening the file, you should also set the same units; it should work.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
stefan
Max has system units settings (telling what realworld size one unit is) and display settings (meaning, in which units to display readouts). The last option might mean that you "read" inches and the model uses "meters".
I always export from ArchiCAD using drawing unit = 1000 mm.
Archicad-user since 1998
my Archicad Book
