Select one and all are selected
Problem I have is when I change the material selection on a column that I have put in front of a house, all the wall materials are changed as well even though they were not selected.
I can change the colour but not the materials.
7 Replies 7
I am not sure, but if you have done this correct, it sounds more like a bug of your installation. I have never seen this by my self, anyone else?
Djordje
This means that your walls and column have the same material.
Are you redefining the material, or are you applying a different material to the column?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
I am trying to apply a new material. I am having the same problem when I try to make one wall a different texture from another, they all get changed to the new material.
If you are doing it the right way, then it must be a bug.
But, are you changing the material in "Wall Selection Settings" -> "Model" -> "Left/Right/Side - Material" ?
Or are you selecting a wall and then change material in "Material settings"?
I am trying to change it through Options>Elements attributes>material.
If I try through the 'wall selection setting' then it will change the colour but not the material.
I think you may be confusing materials with textures. When you do it through Element Attributes, you will change the look for everything that has that material assigned to it.
To change a material, you need to just select the material from the long list. However, there needs to be a texture (JPG etc.) associated to that material (assigned through Element Attributes>Material), or you will just get a color.
Richard
AC26 (since AC6.0), Win10
Thanks Richard
Thats done it
