Tim Ball
Sun Position Error
Tricky setting I came across recently.
If you change the sun position for a camera view in the view settings, it looks fine in the saved view. But when you place that saved view onto a layout, the sun setting defaults to the camera sun setting.
Tim Ball
AC26, iMac
User since V5
3 Replies 3
Erwin Edel
Did you redefine the saved view? (In the View Settings)
Did you modify the camera to current view settings? (Right click camera in Project Map)
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Tim Ball
Yes to both. That made the saved view correct, but when that saved view is placed on a layout it takes the sun location from the camera, not the view setting.
Tim Ball
AC26, iMac
User since V5
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
This is a known bug in ARCHICAD 22. We are working on a solution and want to release a fix for this in an update. You will find it as fix #256843 in the update release note when it is fixed.
I know it is not ideal, but a way to work this around is to save independent 3D perspective views instead of saving multiple views of a single camera (or duplicate the camera for each different view).
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
