Sun Study_CANT create film_ONLY images
I can create a sun study but the save as option - when saved as a film - saves the film as 0 Mb - and doesn't open as a result. The format is the default .mp4.
Any ideas ? The collection of saved images are saved without a problem - but the film doesn't save.
1 Solution
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Hello,
There is an issue I remember that if you were using a High Resolution screen (e.g. 4K), and Windows was upscaled (e.g. to 125%), then the sun study video ended up being completely black (issue #250854 & #66536). It is not the exact same result, but it is possible that you have a problem with upscaling, only you do not get a black video, but an empty one.
Could you check whether you have any kind of scaling applied in the windows display settings? (Start > Settings > System > Display > Scale and Layout)
If so, then please turn it back to 100%, restart the computer, and then try saving the video again.
If that wasn't it, then maybe the video coding component of ARCHICAD is broken on your computer. Try completely removing ARCHICAD from your computer, get a new installer from graphisoft.com (to make sure your installer is not broken either), and try reinstalling it.
Let me know if this helped. If not, we will need to look for the solution elsewhere.
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
Go to post
7 Replies 7
Erwin Edel
I recall having problems a long time ago where it would not save to a network location, so I tried desktop instead and that worked.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Lingwisyer
Guru
Is it managing to save out every frame? Or does it not save the last few frames?
Ling.
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Hello,
Regards,
GRAPHISOFT
Alex
I have not had chance to check yet...but will do thanks
yes - my video if a black video
Daniel,
Looking firther in to this black screen issue when videos are saved as sun studies.
I believe the DISPLAY screen shot you sent is from Windows 10 ? I am on W7.
Lingwisyer
Guru
atfonit wrote:
Daniel, from Windows 10 ? I am on W7.
I believe it was OS independent.
Ling.
Lingwisyer
Guru
I feel like Daniel's post should be pinned. Answer to what appears to be a common question.
