Dennis Koufou
Sun Study not saving as movie file
I am using AC 23 and just discovered the sun study doesn't save as a movie file. Is anyone experiencing the same issue?
9 Replies 9
Lingwisyer
Guru
That is when you have set the Result as MP4?
What are you getting?
Hey Dennis,
I just tried in 23 and it works as either an MP4 or Windows Movie File
My machine is still running Windows 10 though, not sure if there is a difference with Windows 11 if you have that.
These were my settings.
Dennis Koufou
Thanks Barry. My settings and WIN10 are the same as yours. When I click on save, there is nothing happening, and the saved file is empty.
Dennis Koufou
Yes, and the other format also ends up with a blank file.
If you click 'Show' does it go through the motions of the sun study?
That is what it does for me when I hit 'save'.
It first asks me where I want to save the file and then goes through the motions of the study.
I am not sure what would stop it from doing this.
Maybe try a new default template with just a slab and a column (shadows turned on of course in 3D styles).
Dennis Koufou
The show button goes through the movie but not when the save is clicked on. I will try a different file and let you know. Cheers Baz.
Lingwisyer
Guru
Saved file is empty...
As in 0kb? Like it is still trying to write?
Dennis Koufou
That's right, yes.
Lingwisyer
Guru
Have you tried saving to a different location?
