Visualization
Surface Settings Default
JB Sties
I accidentally changed the Surface Settings for 'Glass: Clear Fast' and need to reset it to the default. Is there a way to do this in the program (AC21) or is there a list for all of the surfaces somewhere?
Thanks in advance -
Jeff Sties, Architect
macOS Ventura v13.6.4
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Graphics Radeon Pro 575 4 GB
ArchiCad v27
In the surface settings with Cinerender engine set, select the surface then 'NEW' and "Replace Settings from Catalogue'.
Search for the 'Glass Clear Fast' in your surface catalogue.
If that doesn't work then you can use the Attribute Manager to overwrite from another file that has this surface.
JB Sties
Barry,
Thank you; your first suggestion worked.
Best,
Jb
32 GB 2400 MHz DDR4
ArchiCad v27
