JB Sties
Surface Settings Default
I accidentally changed the Surface Settings for 'Glass: Clear Fast' and need to reset it to the default. Is there a way to do this in the program (AC21) or is there a list for all of the surfaces somewhere?
Thanks in advance -
Jeff Sties, Architect
Mac Studio Sequoia 15.6.3
Apple M3 Ultra
96 GB 2400 2TB
ArchiCad v29
1 Solution
In the surface settings with Cinerender engine set, select the surface then 'NEW' and "Replace Settings from Catalogue'.
Search for the 'Glass Clear Fast' in your surface catalogue.
If that doesn't work then you can use the Attribute Manager to overwrite from another file that has this surface.
Go to post
JB Sties
Barry,
Thank you; your first suggestion worked.
Best,
Jb
Apple M3 Ultra
96 GB 2400 2TB
ArchiCad v29
