Take a look
I created this little scene and rendered it lastnight, I can't believe that a Lightworks novice like me can create such real life images so quickly.
Graphisoft has done an incredible job with 9.0 and lightworks.
Any comments will be greatly appreciated.
117 Replies 117
Dwight
evidence of oversampling - see windows too many lites at "3" rediuced to "1"
Dwight Atkinson
Dwight
two hours for how many pixels?
Dwight Atkinson
Dwight
and your ambient?
Dwight Atkinson
600x404 300 dpi
100% ambient
The settings should all be in the file.
Dwight
thanks.
this is a hard one. I am not happy with my results. you ae either talented or lucky.
Dwight Atkinson
Dwight wrote:
you are either talented or lucky.
Or perhaps both? 😉
PS Why of why would someone with 9.0 use the W1 Casement 70 part from the 7.0 library?
Dwight
did you get a missing fill aggro, too?
Dwight Atkinson
Dwight
i just discovered an interesting thing about the windolite.
if you slide the intensity up and down, it changes the number of light sources. hmmm.
There's the explanation for the long rendering time - window light intensity.....
Dwight Atkinson
Yeah, I had a missing texture too ... no big deal there though.
Yes, I discovered this peculiar relationship between intensity and number of lights some time ago. It is very frustrating, and I'm thinking of modifying the GDL since I really don't want this behavior. (Also, want a fill covering the light 'rectangle' when I rotate it flat to shoot up at the ceiling so that I can select it with magnetic arrow tool.)
Now, the interesting thing from my end is that this image renders in 2 minutes flat at best/best with the lights per window light somewhat reduced and the sun reduced to 3 lights.
Dwight
about the same time for me....
Dwight Atkinson
