muzedesigns
Tiles in Lightworks
I am preparing a bunch of materials for an overnight batch render.. and I am struggling to create my tile textures for Lightworks.
There are 3 different tiles colours used throughout the project in different areas.. each tile is 600mm x 600mm..
I am not sure how to create a material to represent the colour tile and size for when I render it out through Lightworks..
Thanks in advance, I have been struggling!
Chrissy
AC14
Chrissy Avramidis
|| ArchiCAD Versions 7-22 ||
|| 27inch iMac Pro (2017) | macOS High Sierra 10.13.6 | Processor 3 GHz Xeon W | Memory 64GB 2666 MHz DDR4 | Graphics Radeon Pro Vega 64 16368 MB||
4 Replies 4
Dwight
Batch render? Right.
For beginners like yourself, use the internal engine dialog to set texture 'sizes' since this dialog uses actual dimensions rather than relationships like the LightWorks dialog does.
Once you've set the dimensional size correctly, switch to the LightWorks material dialog and click the"Match Internal…" button.
Now, if your tiles require mortar/seams, you'll need to add this to the image in a photo editor.
And: If you want the rendering engine to express the depth of the dark mortar lines, add the tile image to the Displacement Class Height Map shader where it will create relief.
Dwight Atkinson
muzedesigns
Thanks Dwight! Always got my back!
Chrissy Avramidis
Dwight
Swell. Just what is that little black rodent you are looking at in your avatar?
Dwight Atkinson
muzedesigns
it is from Banksy's "Girl on Slide Blowing Bubbles"
http://www.banksy-wallpaper.com/banksy-wallpapers/bubble-girl.php
Chrissy Avramidis
