Visualization
Top View Perspective Render?
Tips on the easiest way to put right numbers in form to get this view??
Thanks 😉
5 REPLIES 5
Are you trying to duplicate effect and view point in the image shown? In archiCAD?
If so, you can use the Parallel projection Settings and click the Custom Axonometry and click the 'roof' image.
Link
That won't give the perspective view they're after.
Trying setting the perspective close to what is shown in the attached image.
Link.
David Maudlin
Fiuni:
In the Perspective Settings dialog box, or with the Camera Tool, set the Camera Z to about 20', the Target Z to 0, and the Distance to a very small amount (say 1", 0 is not allowed, on my system the Distance resets to 0.394").
HTH
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
the birds eye settings worked for me and I do a cutting plane of the project so the walls are black solid. it looks better like that.
