Visualization
Top down 3D axonometry view cut plane
Pato99
I got the idea from another topic and did this cute little top down render with the axonometry view.
I'm wondering if I can set the cut plane height just for that camera or some other way to show the openings and windows. I can't seem to access the on-screen cut plane from this type of camera.
Rendering was on high texture 300dpi, 2.5 hours -_-.
Versions 10 to forced subscription
Please vote for Constant thickness to mesh What will GS do when they reach 200 votes? Less than 30 votes to go!
Please also vote for my whishes, as 200 votes in 6 months is an impossible target, don't be a bystander:
1. Relative file locations | 2. Auto text in Publishing | 3. Model types to Grasshopper | 4. Index Numbers in Search | 5. Step through Elevations | 6. Rhino is better than ArchiCAD
Here's a reminder of what you're voting for: Wishes Delivered
Hi, I don't know how did you set up the view, but you should be able to change the cut plane using a 3d cutaway.
The way I set up those plans is:
Open a regular 3d View without camera.
Cut the plan to the desire height.
Change the view from Perspective to Axonometric.
Use look to perpendicular of clicked surface, and click in the floor slab, that will make the view from the top.
And finally save the view with the settings.
With this method you can change the height of the cut plane any time you want and just re save the view.
Pato99
Ok perfect, I missed the first step being "use the 3d cutaway" before going into the view.
That's got it, Thanks.
