Visualization
Transparency in Renders & PDF sizes
Link
In ArchiCAD 7, we could save our ArchiCAD renderings as a 'True Color - 32 bit' tiff image, which could force our background to be transparent. Then we all sat around and ogled over our cool renderings that we could take straight into Photoshop and overlay on an existing background, or set of backgrounds. What happened to this feature?! I feel the need to ogle.
And can anyone enlighten us on the process of saving a Photorendering as PDF? If I have an ArchiCAD rendering that is 1000x1000 pixels at 72 dpi, and save it as a PDF (at 72 dpi), then open it up in Photoshop, the image size shows as 332x332 (1/3 the original size) at 96 dpi!.
It's just a bunch of dots, right?
Link.
I think what you are dealing with is Acrobat's (if that is what you are using) own compression. Just go into the print driver setup and adjust the compression settings or just turn them off. You can then save that setup to be used under this situation again.
Link
Hey Brian
Thanks for your reply. I have tried just about every option in the ~Amyuni~ driver dialog, to no avail
Link.
