Visualization
Transparency with the sketch renderer
Hi Guys
Hope you are all having a super day!!
Just a query on whether it is possible to have transparent glass with the sketch renderer. I'm finding that my pool fence is obscuring some objects I would like to be visible.
I love the outputs you can get with this engine, and transparent glass would be the icing on the cake.
Thanks very much
Tony
6 REPLIES 6
Some one might correct me on this,
But im pretty sure its toggled in the "3D Window Settings" Shown Highlighted.
Just switch this to on and the Sketch renders should have transparency.
Im working in 11 but i was certain that in AC10, AC9 etc there was a transparency slider, inside the [Options] in that menu, which determined what percent transparency was see through in renders or not.
undefined
You're thinking of the Open GL transparency setting, under your set percentage = solid, over the percentage = totally invisible. Fixed in AC11.
Link
That's right.
And don't forget that the transparency can be saved with a view.
Link.
So by "fixed" you mean it now just goes from the materials own attributes, in terms of solid - invisible ?
Probably.
thanks guys
That worked a treat...
The more I use it, the more I like it.....
(well most of it )
