Transparency with the sketch renderer
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2008-04-16
03:18 AM
2023-05-11
12:21 PM
Noemi Balogh
2008-04-16
03:18 AM
Hope you are all having a super day!!
Just a query on whether it is possible to have transparent glass with the sketch renderer. I'm finding that my pool fence is obscuring some objects I would like to be visible.
I love the outputs you can get with this engine, and transparent glass would be the icing on the cake.
Thanks very much
Tony
6 REPLIES 6
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-04-16 06:04 AM
2008-04-16
06:04 AM
Some one might correct me on this,
But im pretty sure its toggled in the "3D Window Settings" Shown Highlighted.
Just switch this to on and the Sketch renders should have transparency.
Im working in 11 but i was certain that in AC10, AC9 etc there was a transparency slider, inside the [Options] in that menu, which determined what percent transparency was see through in renders or not.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-04-16 06:27 AM
2008-04-16
06:27 AM
MVP wrote:You're thinking of the Open GL transparency setting, under your set percentage = solid, over the percentage = totally invisible. Fixed in AC11.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-04-16 06:31 AM
2008-04-16
06:31 AM
That's right.
And don't forget that the transparency can be saved with a view.
Link.
Link.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-04-16 06:39 AM
2008-04-16
06:39 AM
s2art wrote:So by "fixed" you mean it now just goes from the materials own attributes, in terms of solid - invisible ?MVP wrote:You're thinking of the Open GL transparency setting, under your set percentage = solid, over the percentage = totally invisible. Fixed in AC11.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-04-16 07:20 AM
2008-04-16
07:20 AM
MVP wrote:Probably.s2art wrote:So by "fixed" you mean it now just goes from the materials own attributes, in terms of solid - invisible ?MVP wrote:You're thinking of the Open GL transparency setting, under your set percentage = solid, over the percentage = totally invisible. Fixed in AC11.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-04-17 12:52 AM
2008-04-17
12:52 AM
thanks guys
That worked a treat...
The more I use it, the more I like it.....
(well most of it
(well most of it
