2008-11-02
04:49 PM
2023-05-26
03:01 PM
Rubia Torres
2008-11-02 04:54 PM
2008-11-02 04:59 PM
2008-11-03 01:48 PM
lardizabal wrote:If you set the fill's background pen to transparent, things behind placed fills will show through. As for the cut fills, though, I don't think you'll se anything behind - for example the internals of a wall behind the cut usually isn't very interesting anyway.
Thanks for the quick answer.
I have already tried using the override cut fills in the model display options, but by this way I can only get solid fills in the sections, is there any way I can change the uniform fill pattern into... let's say... 25% fill?
