Uniform Fill Cut Surfaces
Using the Section Tool in AC12, I wanted to set all the cut elements with uniform fill, just as you can with "uniform pen for cut elements" in the model display options. Is there any way to do this quicky and to be able to choose the Fill Type?
Thanks in andvance
3 Replies 3
Djordje
Explore the Model View Options
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Thanks for the quick answer.
I have already tried using the override cut fills in the model display options, but by this way I can only get solid fills in the sections, is there any way I can change the uniform fill pattern into... let's say... 25% fill?
Thomas Holm
If you set the fill's background pen to transparent, things behind placed fills will show through. As for the cut fills, though, I don't think you'll se anything behind - for example the internals of a wall behind the cut usually isn't very interesting anyway.
