Visualization
Vectorial Hatching?
How to get the right fill with the right size?
options > attribute settings > fill types
When I do changes at the fill types setting, bitmaped pattern,
why can't I see the changes on the sections/elevations view??
Jv
5 REPLIES 5
Djordje
Jv
Because bitmaps are for symbolic representation.
You should edit the vectorial part of the fill to the right values. That is used in the S/E
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Thanks Djordje!
I'll try that 🙂
Well, I'm not into all ArchiCAD elements,
so, If someone can please tell me, stepbystep,
on how I can make different panel size in 2D view (sections/elevations)??
Look at the images, I want it to be tighter/smaller..
In "Fill Types" settings window, under "Edit Vectorial Pattern" is option "Spacing" for width and height. Play with it.
Dear Miki!
THANKS!!! ..i made it!
Now it's time to play 🙂)
