2026-09-14 07:43 AM
Hi, I'm looking for some help to remove the wall from my sliding door. I realize the walls are meant to host the door. I have both the wall and the door in new renovation and all of my other doors (none this type) display correctly.
Solved! Go to Solution.
2026-09-14 07:56 AM
Do you have adjacent walls in which this door might be placed in? Door only makes a hole in the wall it is assigned to.
Easiest way to check is, with the door selected, in 3D, press F5 and then it will show the wall & door. If the Wall is a different one from the one where the door is in the image, delete the door and re-place it in the correct wall.
2026-09-14 07:56 AM
2026-09-14 08:04 AM
Legend. Never even thought that could happen. I guess I just set it in higher.
