jwoodyer
Wall continuing through sliding door in 3D.
Hi, I'm looking for some help to remove the wall from my sliding door. I realize the walls are meant to host the door. I have both the wall and the door in new renovation and all of my other doors (none this type) display correctly.
1 Solution
CosminF
Do you have adjacent walls in which this door might be placed in? Door only makes a hole in the wall it is assigned to.
Easiest way to check is, with the door selected, in 3D, press F5 and then it will show the wall & door. If the Wall is a different one from the one where the door is in the image, delete the door and re-place it in the correct wall.
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Go to post
2 Replies 2
CosminF
jwoodyer
 Legend. Never even thought that could happen. I guess I just set it in higher.
