Visualization
What about an user forum for ArchiLumos 2.0?
I“m quite surprised with Archilumos rendering radiosity images inside ArchiCAD. What a workflow! Better now with the release of ArchiLumos 2.0 dated to november 8, which comes with a better integration with ArchiCAD.
What I miss is a user forum at Optgraph“s website to share tips, images and questions with others users. Maybe we can create one on Yahoo groups or something else. What do you Archilumos users think about it?
Regards,
Ricardo
30 REPLIES 30
stefan
Are there ArchiLumos users?
(Sorry if this sounds a bit sarcastic, but there has been a long time since the program was first mentioned and the day people outside of Sweden or Japan could actually get to know it, through the demo.)
Archicad-user since 1998
my Archicad Book
Yes, there is a small number of ArchiLumos users, but I think this will change soon: now with the release of version 2, Optgraph decided to have a more aggressive marketing, they are recruiting representatives / distributors. I think they waited for a mature version to be distributed worldwide.
If anyone wants to have radiosity images rapidly inside ArchiCAD, I strongly recommend ArchiLumos. Lightworks without radiosity is waste of time.
I think Dwight uses ArchiLumos... Do you Dwight?
Dwight
I have used Archilumos.
It has many drawbacks.
Without pronouncing on the new version, these drawbacks were:
1: reliance on limited ArchiCAD material definitions.ie: you are better off in raytraced Lightworks images than trying to radiositize basic ArchiCAD materials.
2: radiosity mapping set too coarse led to staircasing of shadow generation - even in Optgraph's own promotional imagery!!!!
2A: radiosity mapping set too fine led to eternal rendering time of the spotless mind.
3: Flakey with Macintosh - Last fall when my G5 was brand new, Archilumos was crashing - we discovered a bug in the code.
4: bitmapped objects obviously incompatible with radiosity solution - intense polygons in foliage disasterous.
5: Low tolerance for object collisions.
Dwight Atkinson
It would be great to see some real world renders of archilumos, (not the stuff on their website) perhaps you you would like to post some of you work and help "persuade" lightworks / artlantis users that this is the renderer to use?
Hello Lennox,
I'm a new user of ArchiLumos and radiosity, what I will show you is my first work for a client (after few tests of course). So I guess it can“t be a good example as I think I will get better since I don“t know yet the tricks of AL.
I'm aware that the best radiosity results I will find in Viz/Vray-Brazil, but I want an internal workflow so will look very close to the development of AL. There are improvements to take, as Dwight said, and ArchiLumos 2 is the start.
Finished with Photoshop
stefan
Ricardo wrote:
Hello Lennox,
I'm a new user of ArchiLumos and radiosity, what I will show you is my first work for a client[...]Finished with Photoshop
Do you mind showing the non-photoshopped version too?
my Archicad Book
Hi Stefan,
The original image is just the same as it, just without the vegetation and the girl. Here is another image of the same project.
What Dwight wrote doesn“t happen or bother me. I tell you what bothers me on Archilumos so far:
1- No alpha channel
2- Bad navigation and no option to save the desired view.
3- No RPC support.
4- Bad website and no user forum... šŸ˜ž
Steve Jepson
This is a good place to watch for ArciLumos news in English. But it is not very up-to-date.
http://optgraph.com/archilumos/hottopics.html
This is my second work with ArchiLumos. Not bad for me.
I hope Artlantis 5 will have an even better radiosity quality.
Ricardo
